If you missed the previous posts, they are linked below:
Start Here
Second Update
Third Update
Fourth Update
Fifth Update
Sixth Update
Seventh Update
Eighth Update
Ninth Update
The progress has been slow the last two months. My partner has been out of town a lot and when he's gone, I have to stay in town and hold down the fort. The truck is about a 25 mile drive from me (at Dad's shop), so I've missed a lot of time on the project. But, I have gotten some things done, and wanted to update progress.
I decided to move the raditor 1.5 inches toward the engine in order to have the room needed for my '99-'03 PSD intercooler. The rear of the support was cut off, a two inch band of 1/8 inch steel was welded on and the rear of the support was welded back in place. The radiator support pins were also moved to the rear. 1.5 rectangular tubing will serve as a spacer for the upper radiator mounts. It's not done but close.
Prior to modification:
Rear of support cut off:
Two inch wide (1/8 thick) steel band used to widen the radiator support:
The pins were moved and the 1.5 thick rectangular tubing used to make upper rad mount spacers:
More to follow:
Heath
Start Here
Second Update
Third Update
Fourth Update
Fifth Update
Sixth Update
Seventh Update
Eighth Update
Ninth Update
More to follow:
Heath
