reklund
Hey guys, I think I've finally got all my issues sorted out with the intercooler, so heres the pics of the piping as they'll sit. I still need to replace one coupler (It's been ordered), and the air filter (Ordered an AEM Dryflow) but you can see how it all sorta fits.
The intake tube is actually the MBRP Downpipe for a PSD, that came with my exhaust kit. It just happened to be bent to the right shape to use as my intake tube. A 3" to 2.75" reducing coupler, and two clamps, and I was setup there. I'll fab a small tab (Rather than the zip ties) to bolt it down to the AC Compressor bracket when the new air filter arrives.
The intake hat is intended for the newer Aurora 2000 turbo kits that ATS sells, and was given to me as part of the IC kit when I purchased it from ATS in June. (They no longer make the correct hat to use this IC Kit with their turbo systems). Since I had the older non-wastegated turbo, I couldn't have used it anyway, as my airbox was right in the way... I had a piece of aluminum tubing welded to the hat, so I could simply use a coupler to attach it to the intercooler piping, rather than use the slip-fit that was designed to go on the compressor discharge. The black rubber tube that is attaching the IC Piping to the intake hat is actually the intake boot for a Scion xB, that was removed to install a cold-air intake. It just-so-happened to be the right shape to work on my setup, without any additional tube bending or welding. I may end up having that one tube re-made to eliminate the Scion parts, but for now it works great.
Post up with questions or comments!
Oh, and another big to Mel on his RDT diagnosis...
Ryan
Ryan
