Well if the lines are loose at the injectors AND the easy to reach lines at the pump. It will move like any gasser distributor. Did someone change the pump and remove the gear cover, gear and pump as one piece?
I came home and looked at the relation of the studs vs the elongated holes and it doesn't seem that there is a whole lot of room for it to move so... Just fun I broke all the lines loose from the injectors and the ones I could get to on the pump to see how much room it would move the other way... About a 1/2" so I'm guessing it's a tooth out? Or needs to come out and moved so we can correctly time it? Not sure which way to go from here but it's going to have to wait until after I go to Seattle this coming week
Ask and you shall recieve Gary.Al it would be great if you could post a pic of the timing tab at the damper showing a clean clear pic of the top dead center line going thru the short fat probe location.
