I'm back in the IDI game!
lotzagoodstuff
Carmel, IN
Those pics are..........confusing. If I didn't know any better, I'd swear that think was parked on it's side in a lake!
Strange that the uphill side of the valvetrain is so rusty, even if it was caused by a bad oil cooler.
Whatcha gonna do with all those rusty components?
:popcorn
homelessduck
:popcorn
It is definitely worse than I was expecting. Funny thing is when I unlocked the engine it fired right up and sounded good! At this point I'm not sure what route to take with it. I need someone to sell me some lift brackets so I can get this thing pulled and torn down. If anyone has a good engine near Southern Oregon PM me!
saburai
I might have one lift bracket. Would that help helps you?
lotzagoodstuff
Carmel, IN
Just pontificating here with a CL in my hand:
So assume cooler leaked, engine was warm and some water/glycol came up the pushrods and onto the rockers before it was last shut down. IMNSHO, the water could have promoted all the corrosion, primarily because under the valve covers was exposed to air for however long it was parked (how long again?). The bottom end and or bores might not be that bad as they got an oil or diesel bath and maybe didn’t corrode. I mean half of the rockers look pretty good, I’m guessing from a coating of oil that never got washed off.
It sounded like it ran pretty fair, I’m just saying it would be interesting to mark all the pushrods/rockers/hardware showing any sign of corrosion, pull them off, Brad blast or media tumble them to clean them up, put it back together run it. You could cut open some filters and/or do a Blackstone analysis. Fun experiment that won’t really cost you anything but time.
You could do a compression test too, but what’s the fun in that? :D
homelessduck
Possibly! But I'm hoping to get a pair.
I did end up doing a compression test lol. I think it was #6 with low compression (250 or so ) and the others were 450+. I am really hoping you are right and the bottom end looks much better! I don't have a way to blast them.. Would a soak in vinegar do the trick?
lotzagoodstuff
Carmel, IN
Sure: vinegar, a wire brush, wire wheel, etc. I would just make sure you really mark all the pushrods, rockers and hardware to make sure they go back in the same spots when you are done.
Again: you got nothing to lose as it already ran with the parts that are in it. Just wondering: what did the oil look like?
homelessduck
I've been soaking a set of rockers and pushrods in vinegar for a few days.. Are the pushrods coated with something that the vinegar would remove? It looks like it did..
aggiediesel01
Houston, TX
One end is supposed to be coated with Copper? or at least a copper colored coating. Isn't vinegar what you soak pennies in to make them shiny again?
homelessduck
Yep , the rocker side of the pushrod is coated in copper right? Anything on the shaft? I have heard that about pennies but never tried it. I don't think vinegar eats copper..(?) . But it definitely looks like it ate something off the shaft. I'll post some pictures tomorrow.
I've seen brand new push rods that didn't have any copper on either end. I'm not sure after all this time, but I think that maybe they were Sealed Power brand.
homelessduck
I definitely would not recommend soaking your pushrods in vinegar... lol.
Scotty4
Acids will always remove imperfections from mill operations: rust and scale often are left depending cold roll or hot roll. If Ford/IH were trying to save a penny, they maybe used a cheap hot rolled material. I've removed milscale, rust, galv with muriatic acid and vinegar quite a few times and there is usually etching left from manufacturer.
