haleywp
New here to the forum and have some questions. It appears there is a lot of knowledge on the forum. I bought a 1994 350 IDI factory turbo dually with 167,000 miles about 4 weeks ago. I am not a mechanic but have performed maintenance and small repairs. I owned a 1995 and 2000 power stroke trucks. I owned 2 Peterbilt (1 1994 machinal pump and a 1998 electronic).
I contacted 2 diesel repair shops here in the Baton Rouge, LA area and they do not work on anything older than 2000. Does anyone know of a repair shop close to Baton Rouge, LA?
- First thing (truck cold no matter what time of day) it starts up right away. When it warms up and you shut it off it starts right away. If you let it set (not for very long say 10-20 minutes) it takes about 20 seconds to start. When it starts it smoke white smoke and smells of diesel.
- I plan to check the glow plugs, glow plug harness, fuel return lines and injectors. I will probably replace them all.
- The truck seems to be using a lot of fuel. What kind of fuel milage should I expect to get in the truck.
