Alright, bear with me, this intro is long.
BACKSTORY:
I got the truck in 2018, and it had gotten a new motor around 2016. The motor has about 80k on it based on when I got it and now.
I have a head gasket that finally bit the dust, I’d seen it coming for a while but she held out for a while. No crossing of fluids, just excess pressure in radiator.
In the last 12 months I had pulled my IP to redo a line, and all the return lines. When I reinstalled, I believe I accidentally over advanced my timing. (Didn’t know what I didn’t know. Too late now, I thought it went back in the same spot.) resulted in 100* hitter EGTs, which I took note of, but thought it was related to something else.
I reinstalled the IP just advanced of the static timing line, which is as close to original as I can remember. I plan on either having a shop time it or buy the tools.
FOR THE PROBLEM:
Once the head gasket finally quit, I
Took heads off, new gasket, per the book, new returns, new GPs, nice and sealed up all around. Started the truck, drove it home, and it hits around 2,000 rpm and then just pumps out black smoke and won’t accelerate any faster than 45mph. It also does this in Neutral.
It has a new fuel filter, no leaks, it starts IMMEDIATELY, there is zero cranking, it’s just running when you turn the key. At Idle it sounds beautiful, no knocks, no smoke.
Based on that info, where would you guys start finding issues?
BACKSTORY:
FOR THE PROBLEM:
