Has anybody Bushed turbo con-rods
Randy Bush
Great Falls, Mt
After looking more my Ford factory turbo engine manual has both the N/A and turbo size listed , weird, typo error guess.
Fision
Alaska
Without being an expert, I'd say that there's no way you could bore the N/A rods out that large. Ok, you could, but the outer diameter of the Turbo rods on the small end is also larger than on the N/A rods. I'm talking about viewing the rod from the side, and looking at the round part where the wrist pin passes through. I think this would weaken the rod enough that it wouldn't hold up very long unless you're at stock power levels. Even then it may not last.
When you say “rod” here do you mean “piston”?
I would want some VERY informed confirmation that the piston was essentially the same blank and would work fine with a turbo pin. And as Randy notes, the machine work would prob pay for new pistons anyway.
No. The small end (the round part) of the Turbo rods is bigger diameter than a N/A rod because of the larger wrist pin running through it. There may also be a larger distance between the bushing and the outside of the round part, but I have no way of telling that.
Booyah45828
Ohio
I'd be pretty surprised if they had separate casting dies to create idi and idit pistons. From pictures of both, the pistons look the same from the under side, but that doesn't say much so measurement with a caliper should be assumed before taking on the task. I'm talking about mahle/clevite pistons fwiw.
As far as cost of the machine work goes, you'll have to talk to your machinist. But installing a steel and then brass bushing in a rod, sizing the hole, and then repeating that process 8 times wouldn't be free either.
Would I recommend doing either process? No, I'd try and sell my current pistons and get the correct ones.
u2slow
bilge rat
Coastal BC
IMO, the turbo pistons are the only way to go. They are a properly built for turbocharging.
There will be a weight difference also as the turbo piston has more steel in it; upsetting whatever stock balancing you had.
