Someone could have mickey moused wired up a glow plug to run outside of its proper location just to trick the controller that all the plugs are working. Due to a possible broken plug in the head, they may not have been able to have a complete set of 8 plugs cycling to keep the controller in check. I did this once except I had to wire up two plugs! I made a pipe that bolted to the manifold and glow plugs fits securely inside. Plugged the harness connectors from the two broken plugs into the plugs in my contraption, and the controller cycled again thinking that it had 8 plugs working.
This was on a 92 that I had to get running during a cold snap. It was either pull the heads and do it properly (out in the cold), wire up a manual switch (didn't have a switch or any wire on me that day), use ether, or do what I did. I made it as safe as is could be and that truck ran that way until that spring, when a manual switch was wired up on a nice warm sunny day. Sure, its mickey mouse. But it did the trick.
