Engine oil for 7.3 idi?
chris142
SoCal
Todays 15w40s dont sheer much. It may be a 15w35 after 9000 miles. Dont worry about sheer.
vegas39
las vegas, nv
Just as others have mentioned, our engines love to drink rotella.
I switched over to delo years ago and that's what we've always used since. I get it at cal ranch for like 13 bucks a gallon, it's pretty high at auto parts stores.
chillman88
Central NY
I have run both Rotella 15w-40 and 10w-30 (clearance at Walmart).
My truck uses/leaks 3-4qts every 5k miles. I wil be trying Delo 15w-40 when my current stash of oil runs out.
You shouldn't have any issues running 15w-40, especially in California. Its been below zero up here overnight and single digits to low teens during the day. Even not plugged in my truck hasn't failed to start yet.
BigDogIDI
John Day, OR
I run Delo 400. I only drink a quart every 2-3000 miles. Has anyone tried Rislone Ring Seal in their rigs?
BeastMaster
Orange, California
I've been running the DELO 15W40 that Walmart sells in 2.5 gallon jugs for about $30. And, like noted above, the old IDI contaminates the oil with soot far faster than it wears it out. So, change often. I could probably stretch that out if I had a good bypass filter.
I change about every 3000 miles or so.
briankk
California
Any recommendations for good bypass filter?
Macrobb
North Idaho
FordIDIot
CA
walmart MOBIL delvac 15-40. 10.47 to 12.97 a gallon. works great in a PSD so it can handle a IDI
for a dollar or two more than the walmart oil its great. ive been using it for years.
chris142
SoCal
Yep thats good oil for sure.
funnyman06
Coventry, RI
My old motor used to drink rotella as well. I typically ran Delo or vavoline with minimal consumption.
raydav
Apple Valley, CA
I have used nothing but full synthetic since the mid seventies. When I got my IDI I first used Mobil 1 because I had it. I then went to the Walmart stuff then to Rotella T6 a few years ago. After a couple trips to SEMA asking about oil for flat tappet cams, I now use T6 in everything; no cats. And Walmart has it in 2.5 gal size. Oil is just about the cheapest item in total cost of operation. Don't cheap out.
BTW, I just started with a clean 93 turbo, clean cooler, and a normal filter. It took 13 quarts.
FordGuy100
Silverton, OR
Mine see's very little miles and long sitting. Synthetic would be a waste for me. If I daily drove it I would probably switch to T6
