93turbo_animal
Cant ya use the "guts" from a 460 or PSD trans in the IDI case?
you probably can but why when the newer cases are also stronger
Thanks a lot. I should have my turbo oil drain tube and gasket today. I hope to have the turbo on the IDI tomorrow or at least by the end on the weekend. Then I can get the pedal assembly cleaned, painted, lubed and installed. The rat's nest of wiring will be tackled after the pedal assembly is installed.Wow Heath The trucks looking amazing Im getting jealious ! I bet your getting excited to get it up and running! Im going crazy trying to get my project done![]()
Eric that's funny. Dad's shop has a 14 foot door. So getting it out shouldn't be a problem. But, I'm not lifting the crew cab like I did the F250 project. Hope you can make it to the Rally so I can show the truck in person.Wow Heath!! I need to come around more often! Looks great!! I just have one suggestion / reminder..........make sure you can get it out of the shop when you're done this time!!!![]()
There was a post on this on another forum. While the differences in the cases are minimal, the guts cannot be swaped without alot of machining. But you can put s47 gasser guts in a s47 powerstroke case
