ODOMETER I need to repair the odometer in my '86 F350 - I think there's a nylon gear that fails on these...I've got the Cab and chassis 4x4 w/4.10 gea
dogobat
la conner, WA
I need to repair the odometer in my '86 F350 - I think there's a nylon gear that fails on these...I've got the Cab and chassis 4x4 w/4.10 gears any help? Truck's bone stock and running great except for this! Speedometer IS working, odometer isn't.
dogobat
la conner, WA
haven't done that, but I think the cable drives both the speedometer and the odometer? Speedometer operates fine.
Brian VT
Maine, USA
When the cable coming from my 1987 C6 (or maybe the transfer case?) broke then both the odo. and speedo. stopped working.
The nylon gear was fine. The end of the cable near the gear was twisted and frayed.
Be careful that the new cable comes up through the dash at the correct angle. My new one was toast within 2 weeks because I didn't pay attention to the routing. I just kinda stuffed it up there however I could get it to the connection.
The Cable runs both. The Odometer is run by the gears.
Looking at the face of the Spedometer, there is one plastic
gear shaft, that goes to the right, and drives another gear shaft faces forward that turns the Odometer numbers.
Also as the spedo cable it turning, it spins a magnet in a cup which makes the needle move to show how fast you are going.
This is what I have figured out, having taken one apart.
I installed a new 6 digit spedo head in my 86 last year.
I wanted it to have the correct mileage.
There is a set of 6 Cogs on a shaft under the # wheels.
Remove the clip on the end of the shaft, slide it out and the Cogs come off.
Turn the # wheels where you want them.
Slide the shaft in and replace ea Cog as you slide it in.
Replace the clip.
I have had Mercedes Spedo`s from the Diesels of the 80`s
taken apart, and both are made the same way.
To remove the Needle, 2 spoons on 2 sides, pry up it should com off.
On the back side are 2 screws, and the Face comes off.
You might be better off picking up a Instrument Panel off
a wreck in a PNP yard and remove the Spedo Cluster and then change the Mileage if your gear`s are bad.
Forget buying a Inst Panel off E-Bay, they think they are gold plated.
