I made some good progress over the weekend and got the heads back on the truck!
I took some pics and will get those posted up as I get more time. I was installing the rocker arms on passengers side and was torquing down the last bolt when I heard a "crick" and felt the bolt "give"
(before the torque wrench hit 20lbs obviously.) So I took out the one bolt already torqued and took the rocker pair off. The other bolt had broken, but broke off above the head so I could just unscrew it by hand.
I must be living right to get that lucky! I took a look at the broken bolt, and by the staining on it, you could see that there was not much holding it together anymore. Again, I got lucky because this thing could have failed at any time! Now I need a new bolt, and the head of the bolt has the Grade 8 markings. Will a standard 5/16" x 18tpi grade 8 bolt work for this, or was there something special about these rocker bolts? Thanks for the help. Todd
