I had a conversation with the machinist a little while ago. I asked him about the plugs between the intake runners. He said he has never had problem with those plugs leaking. I asked him about when he hot tanks the heads if that solution eats out any sealant that is applied to the plugs at the factory. He said no as he uses a "milder" solution because he does so much aluminum head work. I asked if he would replace the plugs if they were his heads and said he would not. He said he will replace the plugs if I request it, but will have to get the plugs, extra time, you all know the story. So, I am going to take a chance on this (and my "chances" have not been working out so well lately either) and I can't say that Brian did not warn me either. The machinist also told me that the right rear pre-cup was "recessed" into the head several thou. and he couldn't believe the HG had gone this long. Well, if I recall one of my earlier posts when I got the heads off, that cylinder had way more carbon build-up on it and I wondered about the injector. The machinist told me I would have been pulling the heads in the not to distant future because of that recessed pre-cup anyway. Now, this engine only has about 108k on it now, and to the best of my knowledge has never been apart, so that pre-cup was that way from day 1.
