1985 6.9 Project
Ky85
West
I understand your implication, I suppose my reservations come from being alone trying to roll a 6k truck in N and shift the transfer case in synchronicity.
It's also early and I'm only on coffee cup #1. I'm firing on about 2 cylinders. Perhaps I am misunderstanding the series of events as you describe.
Ky85
West
Thank you to both of you!
Makes sense, I needed a lil more 'splaining.
DaveBen
Ukiah, Ca
If the transmission is in neutral and you roll the truck a little it will cause the transfer case gears to move without a load on them. This will allow you to shift into or out of 4 X 4. It will grind a little but will not hurt anything. I have been running four wheel drive vehicles since 1972 and never messed up a transfer case.
Selahdoor
Index Wa
Only time I have ever actually seen for myself, a transfer case messed up, was on a chevy.
Friend of mine was out with his cousin. He gets out to unlock the hubs... Cousin gets out to do the other side.
He left the transfer case engaged.
Transfer case pretty much 'splodes' internally.
Cousin only spun the hub halfway, and left it floating in between.
This will not kill a Ford.
On my 89... Passenger hub broke. Wouldn't lock into either position.
But I didn't find out until I had driven if for weeks, In and out of 4wd.
Felt like it was locking in and out. But it wasn't.
Didn't hurt a thing.
Replaced the hubs, and it was just fine.
Ky85
West
My last car was a Mazda 3000/Ford Stranger so forgive my hesitation!
Oil burners got the knowledge, ty ty
Ky85
West
New door seals about 2 months ago..they are still sticking out a lot. Seems that its rubbing on the engine side near the hinge. I thought that they would settle by now. Has anyone had trouble with this too?
I've played with the post that the door catches on and can get it slightly closer. I'll take them all off and do it again maybe some adhesive to seat that stripping down reel good.
hacked89
Bucks County PA
Yea I bent the metal lip when I installed mine until it closed smoothly. I also tested a bunch to find where the actual spot was that needed to be bent instead of bending randomly everywhere
Sent from my SM-G955U using Tapatalk
Cainon
Smithfield
Agree with Wes, I replaced my bushings few months back. Big difference. Little hard to open sometimes but stays shut good
Ky85
West
Got those on. Bent the metal in from cab.
still sticking out..I ordered new pins for the hinges..maybe the old owner brought the doors in closer as the seals worn out..
Not confident with hinge play but if that's what it takes. I've sunk my teeth in now!
Ky85
West
Messing with that striker bolt placement has had some success. Passenger door is now flush..and really hard to open from outside. Going to leave it shut for a while and try to get it 'green broke' at least.
Thinking I shoulda done same on driver side before I went messing with door alignment. Live n learn..
On to the rusty hood, prime it up and hit it with a navy base coat. And try to seal up the windshield leak. One treatment of flowing silicone wasn't enough, gonna try to hit that upper windshield trim real good.
Winter is coming and that box gotta be tight tight tight.
Here's a action shot of some concrete mix I got the other day. 25 bucks for all that!
Ky85
West
Hood done been un rusted
