I'm going to look at this motor tomorrow evening but I'm not sure if the fan belt system can be changed over to the serpentine belt system and I'm not sure if the van motors are even the slightest bit different than the F-series motors.
What I need to know is will this motor swap over to my F350 CC without any mismatches or hardware issues?
Here is the link to the motor...
Thanks for the help, I just got the truck back from the shop and they said I have major issues, namely wrist pin or a broken piston... They think it will cost more to fix than the truck is worth...
I mean, "Who the frell cares?"
So anyway, if you guys think they are the the same motors, (mounting pattern and plug and play for the serpentine belts) then I can buy the motor (if it passes the audio test, the smell test and the SCA test) with confidence and get my truck running again by Sunday evening!
As usual, I eagerly await your responses...
