hmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm
Lots going on in this conversation. For the most part, I pretty much agree with everyone, especially Wes's comments.
Goal: don't create a traffic jam, doesn't matter where I drive but be able to cruise with good fuel economy and low noise.
With that huge rig, there is no way you can get both "keep up with traffic" and "get good fuel economy." Aim for one. You can't get both.
Here are my mods on my IDI van for fuel economy:
http://www.nickpisca.com/diesel/turbo/the-great-big-list-of-eco-mods-for-6-9-and-7-3-idi-vehicles/ Maybe some of these will help you with eeking out 1 or 2 more MPG than what you are currently getting. I'd be very surprised if you get better than 15mpg on that beast with a tailwind and going down a grade.
Frankly, even with a decent turbo, you aren't going to be keeping up with traffic. The turbo will help, but
Even with a wicked wheel 2?
I put a Wicked Wheel 2 on my van's hypermax kit, and it did help a lot on the lower RPM's. Check it out here:
http://www.nickpisca.com/diesel/tur...lation-on-a-hypermax-idi-van-turbo-kit-video/
The problem with the hypermax van kit (amongst other things) is the low RPM issue. The WW2 does help with that so it's a moderate improvement. Also, thanks to the doghouse access, the WW2 install is easy peasy. I'd recommend it if you are putting in that hypermax kit in the RV. You might even want to install the stock hypermax kit, tune it, and drive it around first, just so you can get a baseline. Then install the WW2 and record the difference.
I'd like to comment on my people's responses, but i gotta run.
Overall, I'd be concerned with that kind of load with a 6-speed and a 3.55 axle. The EGT's will be a lot with a 90cc IP and hypermax. I have that exact setup, but instead of the 6-speed, I have the C6 + GVOD. Even with the WW2, if I go up a decent grade with a fully loaded van, I have to feather the pedal to keep the EGT's under 1200. The boost is fine, but it's just too hot. I gear down when I'm above 6000 ft like in Colorado and whatnot. When I was driving across Wyoming last summer, I had no problems with the C6 gears, but once i got the GV engaged and tried to keep up with the 80mph wyoming traffic, the EGT's would start to build up. My clubwagon is a brick, but that RV is driving a cinder block.
Now factor in the added airstream weight and wind resistance, and you'd have lots of EGT issues for sure. And you could just turn down the pump, but then what's the point? You lose what little boost that Hypermax kit will put out, even with the WW2.
I'd wager your safer bet is the 4.10's with the 6-speed, 90cc pump, ww2 + hypermax kit, UPGRADE that exhause to have straight-thru high flow muffler and that'll hopefully keep your EGT's at a 1000 deg max, but who knows. Maybe try an innercooler if you have the real estate for it. I've been putting that off on my IDI van for ages. I need to get back on to that project. That RV is a wildcard when it comes to predictions.
