JosieGallows
So I'm about to install precups and have the heads machined. Should I use loctite 620,640 or 680 to keep the cups from getting ripped out by the cutting blade. I know 680 and 620 Loctite is "thicker" while 640 is "water thin"
Also 640 only cures on active metals. And the precup is ceramic coated Inconel. But the Iron head should be enough to cure the Loctite I assume. I'll be waiting for about a month to have the heads machined anyways, so it'll be cured.
Need advice on what Loctite to use.
