Shadetreemechanic
You might be able to take it out and repair it. I had a bad sender on my 85, pulled it and found that one section of the resister was bad. I worked on it a while with a soldering iron and it works fine now.
What year truck do you have franklin? I'm buying one with the same year as mine, but from a 250 w/ 460. It's drop in. Just shove a piece of hose on there where the fuel pump would go (if it were being used in the gasser). The elec connections may be differ (4 prong as opposed to 2 prong) but no worries, just plug the connection in.
Replacing the sending-unit with another direct-replacement is a very poor choice; there are many much better options that are far more reliable and about 1/10 the cost.
In about a thousand similar threads, I have posted a link to a very well-written pictorial TECH article showing how to retrofit a generic J.C.Whitney sending-unit onto the factory assembly; I did this on my truck many years ago and the results are far more reliable than the factory units ever were.
I just recently switched over to a new computer and thus cannot post the link at this moment.
An even better option is to simply install plain-Jane SunPro senders in the tanks, along with matching SunPro gauge units in the cab; thus, you will have separate individual gauges showing the level in both tanks simultaneously.
On a side note, be aware that most of the 6.9 and 7.3 equipped U-Haul trucks were I-H chassis and thus will have I-H electrics and such.
There were a few Ford 1-ton chassis U-Hauls with IDIs, in which case parts should pretty-much be a direct swap.
I sort of believe that the U-Haul Fords had ONE single big saddle-tank, instead of the more complicated two-tank system.
thanks for the info everyone.
Midnight - every post i can find from you on the subject is you telling everyone in a thousand posts you already told everyone about the write up lol. never see an actual link so i made this thread.
The front sender probably isn't too bad, being it lasts longer before it shows empty. The rear, forget it, it's going to need replacing. The sending units i've see so far, say they can only be used as stand alone units. Which is a problem since everything is one unit submerged in ours, correct?
