kickdheney
IDIoit from first glance the engine looks solid I talked to the PO and he had the engine remanufactured at motorworks HI Tech engines in spokane 18000 miles ago. I called Motorworks with the serial number and they said the engine had a full rebuild to factory spec. This rebuild took place around 10 years ago. I think the engine has been sitting for about a year and a half. I thought i heard a metal chirping as well. Ill take the belts off and see what that does. I can see that the vacuum pump pully looks bent. I moved and cleaned the passenger ground and it seems to be starting up faster. Does this look and sound about right for starter motor speed. Ill take the belts off next and post a video
<iframe width="560" height="315" src="
" frameborder="0" allow="autoplay; encrypted-media" allowfullscreen></iframe>
