the best way ive found to check compression
honestly im not a fan of compression tests.
sure they will tell you a cylinders pressure.
but a leak down test is my preferd method.
you can listen to the exhaust, intake, oil pan and coolant to find if youre leaking somewhere.
however.
preping a engine for install in my ranchero,
i went to adjust the valves, and the kids nerf ammo were put in the injector bores to keep it sealed it.
i think its done its job, and confirmed i got good compression :cheers:
aaaaaand.... its installed!
if youre interested in following this build....
chillman88
Central NY
Have you ever run those rockers before or is this engine the first time with them?
olsen726
