T19 to ZF5 1986 F250
We can use PSD flywheel, clutch and pressure plate behind IDI with ZF and it will fit/work/not vibrate from balance issues?
The 6.9 and 7.3 IDI have the same bolt [pattern for the flywheels so it will work behind a 6.9. The PSDs use 10 bolts for the flywheel while the IDIs use 9 so they won't work on a 7.3PSD.
No. You can't use a PSD flywheel behind a IDI because it will not bolt up due to the different number of bolts. That is unless someone's done it and I don't know about it.
Wait what? We can use PSD flywheel, clutch and pressure plate behind IDI with ZF and it will fit/work/not vibrate from balance issues? I hadn't heard that. I think I have PSD flywheel somewhere around here from when I got my ZF.
I am reading that the PSD has 10 bolts that hold it to the engine, and a IDI has 9 bolts that hold it to the engine?
Yes. That is correct. Some of the IDI flywheels and flexplates do actually have 10 holes, but #10 is a lot smaller than the others and is NOT a bolt hole. It's there because some of the early crankshafts have a locating dowel on the back of them. I only mentioned that because if I didn't, someone would say that theirs has 10 bolt holes and post a picture.
Just because it is a hole, doesn't mean it is for bolts ;)
willyd
AZ
I'm about to do this same swap in my 86 - can you post some pics of your crossmember setup?
willyd
AZ
Crud. Got busy with work and totally forgot to take that picture.
All good! I measured my T19 from the bellhousing back and the mount is in the same exact spot as the ZF5 so it should be fine.
jwalterus
Made in America
Air Force
Garrison, ND
Iam using a LUK Clutch, but in my 86 with the T-19 Trans.
No complaints about it, it`s a 12" Clutch.
Iam using the Throw Out bearing from O`Really`s, all metal one.
So far so good. Been in 1 1/2 yrs so far.
I had the Clutch fail quite a few years ago, I was 25 miles from home, and had a shop replace it.
Couple years later I had this squeek, squeek, squeek sound, took a while and figured it was the TO bearing. replaced it with an O`Really one, (all metal) and couple yrs later it did the same thing. The Bearing was all floppy and loose.
Replaced with another O`R one and ran a long time till I put in the current one.
They are a sealed bearing, maybe they all come down the same China assembly line and don`t put in enough grease.
Too bad there isn`t a way to squirt in a bit more grease.
Thank You for posting this.
I was doing a Google search on the part #, and this
E-Bay listing is the cheapest I found.
$30.00 and free shipping.
Prices seem to range between, $40.97 - $99.99
Saw a Timken on E-Bay $45.00, says used but is new,
box is a bit scrunched. Made in U.S.A.
Here is a cross reference on related part numbers.
Not all are made in the U.S.A.
Part Interchanges​
I know I'm late to the party, but you forgot the T-19 unicorn (which I'm holding in my hand currently as I haven't dropped my trans since I got it)
Ford F1TZ-7548-B
This ebay listing shows 48 available.... https://www.ebay.com/itm/388831459042
