T19 bellhousing
Black dawg
USA
I remember saying awhile back that the 460 t19 bell wouldnt work for redrilling the 6.9 7.3 pattern, because the one that I had wouldnt work for sure......
Well, aquired a few different bells (all alum hydraulic bells, and the 460 and idi bells are the same casting. The 460 bell for sure could be made to work with the idi and the idi bell could be redrilled to big block pattern.
Have enough stuff that I should be able to build a really good drill template (that engages pilot holes for perfect alignment) at some point.
If it is that easy, it makes you wonder what Ford was thinking. It had to be some sort of political reasons in the ranks of Ford Motor Co. For instance, some deal with the union and keeping foundry workers busy, or something like that.
kbenz
kannapolis, NC
I’ve been trying to find the bolt pattern for this. Would you mind sharing this information?
Black dawg
USA
I will see if I still have the parts. Project went sideways and some of it accidentally got scrapped, so dont know what I have left.
u2slow
bilge rat
Coastal BC
Hahaha!
Never seen engineering go sideways and customers/operators get to live with the results for 20 years? :fan:
I think it's more likely a casting efficiency. Then machine the bell for 460 or diesel. By the time the ZFs came around, they were purpose-cast for each specific pattern.
The easiest way to have a bolt pattern template is the factory engine/bellhousing adapter.
kbenz
kannapolis, NC
Hahaha!
true. I was wanting to try and put something into a .dxf file
Olds64
Edmond, OK
I don't know if this would help, but Speed Gems provides transmission adapters for a ton of Ford engines and transmissions. I'm familiar with them because they offer a transmission adapter for the old Oldsmobile engines to a modern automatic, which eliminates the dinosaur Slim Jim Rotohydramatic. A transmission that is only surpassed in suckage by the new 10R80! LOL
kbenz
kannapolis, NC
nobody seems to make anything for the 6.9/7.3
Hahaha!
Here's a old picture that used to be on here that shows what needs to be done. Think about the c6. They were making the c6 cast with the 460 bellhousing for years. Then they decide to contract with international to use their diesel engine in these pickups. But it had a oddball international bellhousing pattern. We need a adapter! What does Ford do? They make a adapter to go from the international bell pattern to some other oddball pattern that matches nothing. So they have to specially re-cast the c6 just for this odd ball pattern they dreamed up.
460 zf to idi by D Franklin, on Flickr
u2slow
bilge rat
Coastal BC
4 of the adapter/spacer bolts go right through to the engine block. Fat chance getting Navistar to recast their blocks.
The recasting of the transmission or bell isn't a big deal, as it appears the one revision (more boss area) made the part dual-purpose 460/diesel until it was drilled.
bneumann22
