BrianC
Ever since I went with a LUK single mass clutch set up the gears in the transmission make a rough grinding noise on start up but mellow out once rpm's increase or when in 5th gear on the hwy. Is this anything to worry about, does it harm the transmission per se? I have about 5,000 miles on the new clutch and this is the only issue. No shuddering on take off like the DMF just the gear roll over noise. Thanks.
Brian
Brian
