"Remote Mounted" turbo
DeepRoots
Tug Engineer
Douglas, Georgia
if the oil pump is electric and it fails, would be an expensive repair as I imagine the turbo would tear up before you knew it.
wwwabbit
Mmmmm Diesel
Sooke, B.C. Canada
Yep, but same thing as your mechanical one in your motor, you put some sort of a dummy light/buzzer or a gage on it. I would be almost tempted to make a separate oil system just for the turbo, a little reservoir and you need the pump+filter already.
Mont91
East Central Montana
What happens when you back into the lake to launch a boat or cross a creek or river, rocks flying up from gravel roads. Seems one would need a snorkel of some sort. How hot does it get pulling hard. If I am under full power with the stock trailer tied on in the pasture is this thing going to be as hot as the converter and start fires.
