Question about fuel filter housing
Sparks-IDI
Melbourne, FL
Well my fuel filter heater started leaking bad so it needed fixed asap. I have read that most guys generally remove it and plug the hole and simply eliminate it. Since I am in Florida, I also saw no need for the heater and figured I would do the same. I did not do the typical 1/2 NPT pipe thread and plug the hole, because I did not want to modify/destroy the housing just in case I ever wanted to re-install a heater. So I came up with a scheme that does not modify the hole in the adapter.
What my question is in regard to is the return line port. When I took the housing apart, I found a spring sitting in the housing as seen in the picture. I did some measuring, see dim. sheet. With the dimensions I measured, a 5/16 dia. check ball would fit at the end of the spring and up against the .260 dia. step. What I want to know, can anyone confirm there that there should be a check ball or check disc there that would fit up against the spring? I have had some issues of air in the injector system, after sitting overnight.
Sparks-IDI
Melbourne, FL
Some additional photos.
Here's a thread.
Another
Another
tbowker
Hudson, Florida
I like what you did with that heater plug. I have a spare filter head that I intend to mount after the fuel tank selector valve and before the electric fuel pump, which I have mounted on a frame rail. The plan is to have a water separator for additional filtration. What type of material did you use to make that plug? I presume that's a buna type "o" ring, right? Lastly, how well has it been working as far as being leak free?
HS108
Diesel Newb
Connecticut
@Sparks-IDI Did you custom machine that plug? Mine is leaking and I stumbled across this post! looks nice!
I have never seen that type of plug. It's neat, but the housing would need to be drilled for it to fit.
Another viable option is to still drill it, then put an npt plug in it. Super easy, did it to mine cause my heater was leaking too.
HS108
Diesel Newb
Connecticut
I was looking at getting the kit from CDD, just was wondering about the OP work
