Ryland
I was changing my fuel injectors/IP and installed all new return lines, gaskets and what not and when I got to the circled hose there was still pressure on it when I took the hose off and it sprayed all the way across the engine bay from what I understand that is a check valve the hose is attached too and it recircs some fuel back to the tank.
When I inspected the hose it is plugged off right where it attaches to the barbed fitting so I’m assuming somebody plugged it at some point.
So I just wanted to check and make sure that I am able to throw that hose out and just put a regular hose on it.
Thanks in advance! I attached an image to this post and hopefully it works
