fordv840
Hi all,
I did some searching and there is some good info about what I am asking but I need to be 100% sure on where to tap this turbo into. Here is my major malfunction besides the mental one!
Everything was going well with the install, got to the point to removing the plug from the block that banks and most of you say to tap into, well, that’s where things went off the rails…..
1. First the pipe plug head, sheared off in the square drive socket.
2. Headed and PB blasted for days.
3. Drilled plug and put an extractor in there but could not get good purchase on the extractor because of the lack of room to get it jammed in there.
4. Put a pry bar against the frame and the socket wrench on the extractor but and broke a 5/16” extractor bit in the plug.
Heated and PB blasted a few more days.
5. Today welded nuts onto the end of the entire mess but they just keep shearing off. I think whoever put this plug in must have cross treaded it and just jammed it home! So I gave up today. I thought, maybe I can tap into the old sending unit location which is now plugged but I cannot get to it as the up pipe is over it.
That leaves me with the need to find another port to tap into and my confusion. I see the other plugs in the block along the oil pan and I read some discussion about using those for an oil pressure gauge etc.
Is there enough flow there to feed a turbo as well?
Is it the same flow as the port on the bell housing?
It seems the factory and most aftermarket turbo setups feed oil from the port on the drivers side bell housing (my broken plug) or the old oil pressure sending port on the rear on the intake area.
Sorry for the novel but just want to be clear and share my pain! I have spent more time on this plug than the entire turbo install! Lol
