I need the check valve found on the 7.3 filter head. I have seen them available somewhere but I don't recall which Ebay seller was offering them. Anyone know who sells them. I never have had this air bleed off on my filter head and am wondering where the trapped air goes that is found in the filter area. My onlt thoughts is its going thru my Moose pump and we do not want that happening. All I have is a fuel in and a fuel out line. No real way for the air to bleed off. I understand how these check valves operate. They bleed off the air till the fuel pushes closed the spring and ball in it. Really simple operation. The only one I have you can see right thru it. When I bought the truck many years ago this valve was capped off with a rubber cover. Why.. I still don't know... Naybe the owner had the wrong return line kit that didn't offer the correct caps for this to operate...
