1992-6.9 said:
What is the best inexpensive fuel pump I should add??
If you want a real high quality pump, the facet Duralift works nicely.Granted it's not the least expensive, but if you buy a holly, you'll be buying another before to long, or having to send it to holly for rebuild. Or you could get a Mallory, they work nice and are user rebuildable, but you'll be putting brushes in the thing every 12k miles or so.
The facet is the factory fuel pumps on new carrier Transcold ****** units and are designed to lift up to ten feet so they can be mounted under the hood for easy access to the built in trash screen ( no need to mount down on the frame )
part number is 30-01108-01SV from a carrier dealer ( facet part #40223 )
They run about $125 and unlike the holley pumps which are designed for sport,and don't hold out very long, these things are designed for constant duty commercial service.
I've had one for about 5-6 months, works very nicely.
If you just have to go cheap, the little Facet cube pumps that most parts stores sell for about $35 will do OK, but they do have to be mounted low and I don't know how long they'll hold out on these things, although I've had them last for years on european diesels.
---------Robert
