I will try to update upgrades and maintenance I done in the last few months.
1. Insulated the door, floor and roof.
2. New rubber flooring, removed the carpet.
3. Installed a rear view camera with 7" video monitor, I have three more cameras to install on 30' 5th wheel RV. One on the rear and each side.
there should be no blind spots when completed.
4. Replaced rear axle seals and bearing, passenger side was leaking. I did both sides.
5. New rear breakes at the same time.
6. New tires all around. Hankook AT2 235/85/16 front and ATM 285/75/16 on the rear.
7. All four new shocks, Bilstens 4600.
8. All four front ball joints and adjusting cam.
9. Installed used door panels found at salvage yard. Still need to repair the window switch broken tabs.
10. Installed MaxTow piller and dash gauges: voltage, fuel pressure, oil pressure, boost on the piller and Pyro, water temp and trans temp on the a dash cluster.
11. Replaced A/C system, compressor, evaporature, dryer, oriface tube, flushed and charged. Blowing cold, aleast the wife is happly now.
12. Install a diamond plate tool box and bedrails.
13. Shop replace my E4OD with 215K with a Ford Remanufacture E4OD. What a difference.
14. Offer-Up puchase 2015 Silverado front seat and seat console. I cut most the botton metal off and mounted the Ford seat rails. Not pretty but the mounting holes matched.
I will get some pictures posted when I can. Wes really liked the front seats.
