Project Mosquito Control...
hesutton
The Anti-Anderson
Bowling Green, KY
Losing my mind. LOL
Classic case of "Project Truck Delirium" or PTD.
The only cure is a cold one in your left hand and a wrench in your right hand. Repeat this treatment until the project is done or you're too "medicated" to continue working.
Heath
88fordidi
nice project I'm loving it!! this has always been my dream project, well, sorta.. I'll be sure to take notes! even though there's no way I can do that body work.. nice work!
hesutton
The Anti-Anderson
Bowling Green, KY
Talked to Dad about the PS pump on the DT466. He agrees that the volume will be too much for a pickup steering box and hydro boost. Pressure shouldn't be the issue, but the volume was his concern. Overheating the fluid and pump is the problem. Solutions........ auxillary oil cooler for the PS system and an inline regulator.
But, finding a different pump with a volume equal to the factory IH system would be best. A hydraulic shop should be able to handle that task (finding or making a pump that's within spec).
Heath
6.9poweredscout
Bleeds IH red...
Northeastern Pa
Thanks 88fordidi. Its not too bad, just start in the hard to see areas, by time you get to the outside areas you'll be a pro!
Hmmm well there is a local hydraulic shop I can talk to. I'll see what they say. I figured the power steering company would have been able to figure it out!
6.9poweredscout
Bleeds IH red...
Northeastern Pa
"I hope your ready to roll some coal! You will have 175cc/1000 max. That's 75% more fuel than Stock. You have the first Omni Moose pump!" This was the text I got from Mel today. Hell yeah!
6.9poweredscout
Bleeds IH red...
Northeastern Pa
well it sucks to cut up a cab that was decent... but i needed a patch panel for the travelette...
i'm going to graph it in the top across the front body line. slowly but steady!
