Project Mosquito Control...
6.9poweredscout
Bleeds IH red...
Northeastern Pa
Back together!
making sure its tight and in place
I definitely clamped it a smidge hard in a few parts, going to have to fill a few dents with mud....cookoo
inside panel
and the last panel up top
LCAM-01XA
my very own hell
Filling dents is easy. It's when you don't clamp enough and end up with a bump that blows... Looking good tho. So you taking this truck to Carlisle this weekend, right? LOL
6.9poweredscout
Bleeds IH red...
Northeastern Pa
I wish I could take it!!
Thanks, hopefully it'll all fall into place when it's going back together! cookoo Gotta decorate with what I know best!
6.9poweredscout
Bleeds IH red...
Northeastern Pa
Had enough friends over to help remove the cab.... ohhhh boy its about to get serious in here!
there she is!
gotta wire wheel it down and do a little touching up with the welder!
My one friend was feeling ambitious so he went to town and got the old exhaust off and the driveshaft out
Now it's time to start mocking up the drivetrain and scraping all the undercoat off the underside of the cab! ;Sweet
6.9poweredscout
Bleeds IH red...
Northeastern Pa
I'm sure you've all been waiting patiently for updates. Nothing exciting, but i'll get you up to speed! :D
nothing better to do on a holiday weekend sunday night but drink beer and scrape the old crud off!
little help from the crud buster...
40 years worth of undercoat, grease, dirt and who knows what.
Smooth out the welds on the firewall, yeah insulation and carpet will cover it but I know it's 110% under it
now for some more rust repair I forgot!
a few more things on the cab then its back to the frame build!
6.9poweredscout
Bleeds IH red...
Northeastern Pa
just some fun inbetween!
takes a lot to swallow 39.5s!
was 1/4 way up the door!
local antique truck show:
Slow truck race!
Brandon vs a friend "stock" 1310
Brandon vs frank
frank vs a big rig
Frank vs mack
Frank vs fleetstar..... frank took it, just more proof IH's are the slowest trucks on the road!:D
6.9poweredscout
Bleeds IH red...
Northeastern Pa
got the old axle out, springs and hangers off.
thowing in some '85 chevy truck hangers and a set of '63 inch chevy one ton springs and then a 10.25 axle.
On the fence if i should bolt like a 1/4 or 3/16" piece of plate steel on the inside of the straight part of the frame to firm things up.... don't want it too stiff though...
freebird01
Post Turtle!
Fort Wayne, IN
i wouldnt... let it flex
not to mention boxing in the frame will lend itself to collect crap and trap rust... look at every F150-350 from the 70's through early 90's... all had c-channel frames and worked just fine
freebird01
Post Turtle!
Fort Wayne, IN
Brad is doing that on his...on the front I could maybe see it with that massive 6cyl but im still not convinced it needs it unless you plan on regularly overloading it beyond its gvw...
is the frame pitted badly like a nepa truck? Or still pretty smooth like a southern truck?
