Well after getting the lights going, I decided to move it to another part of the yard. Blew the pitman arm seal in the steering box I had resealed. Got a new seal, and put it in. Didn't blow out, but was leaking. The hell with it. Bought a red head steering box, lee pump, and got a cooler. It's been raining and snowing, so I haven't been able to put them in till today. I pulled the old stuff out so I could return the core to red head. One mistake I made was that the red head box comes set in the middle of the range. I tried to put the drag link on, but it was a little off. Figured I'd tighten up the pitman arm a bit in case the angle was due to not being not installed all the way. Bad idea, it moved the box from center so I had to spin the wheel from end stop to end stop to find the center. Not two bad. Exactly 2 turns in each direction from center for the new box. After finding center, I jacked up the wheels and attached the drag link, connected the borgson steering shaft with the wheel centered, and only then tightened up the pitman arm. Learned a little.
Went to pull the pulley from the pump, and that's when I noticed the little lip that the pullers grab wasn't there. It was just flush. Weird. After some time, I check the back of the pulley, and low and behold there was the little lip. Geeze. Some genius put the pulley on backwards. Did I mention earlier that I resealed both the steering pump and the steering box. So the genius was me. Doh! Scratching my head how I'm gonna get this off. I have another pump, so I can get a pully quick, but I think these are getting hard to find, so I'd like to get this one off. The center of the pulley is recessed back behind the extended 2 grove pulley, so a single bearing splitter would probably bend the grove. I was thinking maybe stacking a small one inside the bigger one and hope I could put it in a press and hold the weight on the center of the pulley so I can press the shaft out. Don't think I'll do this again, so live and learn. Anybody that's been though this I'd be interested to hear what you tried and how it worked.
I think I'm starting to come down with the crud that eveyone in the house has. Judging on how they are feeling I may not be doing much for next couple days.
