Clutch Heim Joint Mod and my trained left foot
jim x 3
1988 F-350 DRW
northern california
A year ago the plastic bushing/keeper in my clutch bellcrank to clutch master pushrod gave out. I fixed that by buying the heim joint with the setscrew and hex head capscrew to replace the bellcrank stud. While that all worked and was a better design than the Ford original, I ended up with a lazy clutch pedal – one that won’t return (completely) to full upright when letting out the clutch. So my left foot has now trained itself to pull up the cluch pedal after each shift.
I decided to finally do something to fix this. I reclocked the bellcrank to clutch pedal shaft splined connection. My clutch pedal then snapped nicely to resting position. However, my clutch is now slipping under heavy acceleration. There is no intermediate spline.
So I take issue with the heim joint mod as half assed. It should have been designed with an adjustment mechanism. I ended up sticking a thin circular shim into the pushrod hole as a fix. But the heim joint hole should be female threaded for a locknut and male threaded pushrod. [And that hole is ~3/8” in diameter – too large for the pushrod.]
Keep this if mind if your clutch mechanism needs this repair.
Jim x 3
PS. While messing with this (with my upper body and head in the driver footwell), I determined the clutch pedal shaft right end bushing was plastic as well. Green plastic powder was filtering down into my eyes and 3 pieces of plastic broke away as I exercised the clutch pedal with my hand. The ~3/4” shaft had hogged out the opening in the potmetal or aluminum bracket. I ended up using a piece of 3/4” copper water pipe cut down to fashion a new bushing.
So sometimes the original Ford design is wholly sufficient for an application, and other times the design certainly did not contemplate a 40 year operational life.
Correct. There is too much movement with only going one spline. The solution is to buy a new bellcrank and try to position it in an intermediate position. There are no splines in the new bellcrank. Those are made when you tighten down the nut that holds the bellcrank onto the shaft.
onetonjohn
California
You have pics? I don't know what the bell crank or hiem joint are. That said, long ago, I used work in clutch/transmission shops, and may have seen this before.
jim x 3
1988 F-350 DRW
northern california
Sorry, no photos. The clutch pedal is, of course, to the L of the brake (pedal and master cylinder). However, the clutch master cylinder is to the R of the brake (pedal and master cylinder) on the firewall. The clutch pedal arm is attached to a horizontal shaft. The R end of this shaft is splined for a short arm (the bellcrank) with a stud at its end that fits an eye in the end of the clutch master cylinder pushrod. All of the bushings for this assembly are plastic, which has turned to powder. The heim joint replaces the bellcrank stud to pushrod eye joint. You can find these for sale on amazon, ebay, and elsewhere.
My issue here is that there should be an adjustment possible in this linkage.
I don't know much about buying them, but there used to be some adjustable rods that went into the clutch master cylinder. I've seen a few.
Rdnck84_03
Kansas
My clutch master from OReilly's several years ago came with the adjustable rod.
James
u2slow
bilge rat
Coastal BC
I replaced the pin/pivot with a bolt and greased it up. New master cyl. No issues.
Here`s a few heads on how to remove the Clutch Rod into the MC.
This thread about adjustable rod.
abcdefg
