Hello all, I just picked up a 1986 f250 4spd 4x4 and she's definitely a project.
The PO had some interesting fixes to say the least. I think ill be rolling through here pretty often.
The problem I am battling now is the clutch sticks down but it disengages just fine. THe PO said he did some custom fab work for the 4spd swap under the dash and that's where he thought the issue might be, so i did some lookin. He fabbed up the lever that connects the crossover rod to the master. To make it all work he took a grinder to the crossover rod and bent the input shaft of the master. To be honest I am not sure where to start on this one, I am assuming i'll need to replace the crossover rod and the master so tips on both would be appreciated including where to find parts and if there's anything else I should do when I have the pedal assembly out.
I am not sure of etiquette so if multiple issues in a thread is a nogo let me know and i'll adjust. PO also drove with no power steering for a while, so the bearings near the tilt knuckle thing are shot to kingdom come. I'm worried because he was yanking on it so much it he could of damaged more than just the bearings. Should I grab a used one or rebuild this one? WHen I pulled it apart there was a lot of metal shavings but I didn't see any cracks in the pot metal. Also my phone is a damn potato so sorry about picture quality
