Originally Posted by zebrabeefj40You must be registered for see images attach
Way back in post #8 I said I've done what the OP wants to do. Cut about 4" outside of the flares on a dually bed. Cut both the inside skin and the outside skin and along the floor next to the inner skin. Bring those pieces home from where ever you cut them and lay them on the floor with the outer skin up. Drill all the spotwelds the mate the bracing to the inner skin. I cut the outer skin just outside where the flare hits. This is the piece you need to splice into the SRW bed to mount the OE dually flares.
I trimmed the SRW bed outer skin roughly the same place with the idea being you end up with the weld line under the edge of the flare. I'm not the best butt welding sheetmetal together so it's a little wavy but not enough that a skim of filler won't fix it. Plug weld the previously drilled spot welds on the bracing to connect the inner skin to the outer skin. Then metal finish to whatever quality you need it to be.
I'm not having much luck posting pics so 94f450sd if you wanna see what I did you'll have to PM me your email addy so I can send pics.
Nick
THANK YOU!!!!and when its done you can barely notice what was done.
f450sprdty aol
Originally Posted by 94f450sdYou must be registered for see images attach
for them to do any bracing they must be welded to the same lip you cut off for the conversion fenders.so again we're back to nothing supporting the side of the bed and more to end up rotting out.
hey rich-
what do you think happens to the welded area of the metal on the inside of the bed where it is butt-welded together? corrosion is accelerated where the welding work was done unless the area is sealed with wax or a paraffin-like substance equivalent to what you find in older MBZ's.
