Have no idea what mlps is but the ZF NSS will in no uncertain terms be installed. I've never previously had a NSS in a truck and the wifey's stang has one and so does her ranger...however neither of these do I drive if I can help it.If the OBS harness is anything like the brick harness, then all he has to do is unplug the entire E4OD harness from the big square connector at the driver-side inner fender, and plug in a ZF5 harness in its place - the NSS jumper would then be built-in from the factory in the form of a short piece of wire looped between the two pins normally connected to the NSS part of the E4OD MLPS. Then inside the cab if he leaves the NSS jumper connector in place he can start the truck without clutching in, which considering the silly design of the stick-shift NSS may not be such a bad idea after all.
Not sure what BIG SQUARE connector you refer to on brick nose, there is ONLY a ROUND one on brick nose!
I"m thinking that there was significant changes from the Brick to OBS systems...however the brown bruin cab is a wiggle stick and NOT a NOTOMATIC, like the grey truck so perhaps a harness swap there will work for me
Thanks guys, helps me know *** to look for...now where is the E4OD ECU so I can remove that for potential future use?
