UPDATE TIME!!!
My friend John Deere Brian...I have three friends named Brian....so it's how I tell Super whom I mean...
Anyway Brian and I have been discussing this build in depth of late. Actually quite a bit, and have been taking measurements and comparing different body mounts between SC and RC and Bronco, as well as floorpans of RG and SC.
So far...So far the SC has a much flatter floor than the RC with minimal lift up at rear where frame kicks up. I wish I could just take some cross sections of them...Hmmm...wait, "LIGHT BULB" cardboard templates of both...Hmmm..I can do that!
Ok back on track, For all my measuring and comparisons, the bottom line, this looks like with 3" lift on front cab mounts below/in footwells and the rad support, and using an outboard frame mount from a Bronco frame, I can swap this cab on with minor sheet metal mods to SC floor.
Bronco/F 1,2,350 foot well body mounts
See it's set at an angle along top edge near frame...opposite side same but mirrored
Notice it drops down
EARLY 80's Bronco/F 1,2,350 rad support mount
3 bolt mounts...used in 87-97 style rad support as well
This THIS is the key body mount...it's the one below rear edge of door on Bronco
nice, can actually be made to sit just above frame if need be, hmm...this would be MY REAR cab mounts outboard of frame I think...These..ARE the KEY I believe, and look simple enough to fab if needed!
This is the SC frame, it's got the LONGER flat section and then KICKS up at rear and the body mounts are on the X member as seen inboard of frame
Drivers side of the underside of SC notice not a great deal of change in height of floor pan???
Slightly different view
Now I don't have a bare RC frame or a cab off a frame so I can only show as you see...here
This is Looking from rear forward on PASS side of RC to show the amount of changes in floorpan
This is + - a wee bit...where the rear body mount section under the floor of the SC would sit...right over fuel sender/lines DOH!!!
Clearly I cannot mount a X member here for the body to mount to and thus those Bronco mounts mounting outboard the frame will likely be the best. I cannot mount the rear of cab like the picture here shows! The stick on pass side of frame is about centre of the body mount be it inboard or outboard of frame as I plan to do
NEXT
