ok let us beat the mpg horse some
KansasIDI
Sorry folks, I’m here to derail this here thread
Wilsey, KS
Modern DPF systems actually tend to be reliable, as we have been using them for 17-18 years. Early DPF systems, such as found on the 6.4 PSD, LMM Dmax, and 07.5-12 6.7 Cummins were very new technology, and used the engine injectors to burn the soot into ash, which was not a very good design. DEF is a bit newer, about 14 years, and has inherent problems due to it’s aforementioned properties.
ttman4
Last Nite's Dream..
Yeah the regen is less than ideal. And I am not convinced the fumes from the DEF burning are safer for the environment than the carbon being trapped and burnt off in the DPF. Carbon is not a greenhouse gas. Falls back to the earth.
During Regen I get about 7mpg. It typically regens for 25-30 miles of highway driving. My experience is I burn an extra 3 gallons during the regen process. So every time it regens, I lose $10-12. Oof.
I'm embarrassed for appearing so dumb when I ask this, but what in the world is "REGEN?"
And what is/does "During Regen" mean?
The closest thing I/we got to anything that might have something to do with these terms might be that '14 Chevy Silverado 2500 HD Duramax 6.6 that I/we inherited nearly 5 yr ago when our son passed. He had already deleted the DEF & put in new exhaust system, etc, etc.
This rig got near 230,000 miles on it.....& I've put 30K of them........and it scares me cause if/when something breaks or quits I FLAT OUT NOT GOING TO KNOW WHAT TO DO TO FIX IT!!!! There so much I don't know bout this rig.
First week I had this rig it threw a code on dash rolling down road & I couldn't read it. Finally bout 5 miles later I got my glasses on & it said "Right Rear Tire Low"......I pulled over & nearly new RR tire was already ruined!!! I flat out had NEVER heard of "LOW TIRE" Codes!!! Turned out the wheels have senders in them to tell Dumb Folks like me that tire is low!
My main point is that I'm way....wwwaaayyyyyy behind the rest of the world!!!!
& I better get Bessie fixed, painted, & keep her cause except for major stuff, I can work on & fix her & keep her going!!!!!
So.....what is "Regen" & "During Regen"?
Clb
Another old truck
nannyfornia
Regeneration of the dpf
In English
Unclogging the stupid filter
It sorta lights it on fire in the filter housings...
In essence
Putting the trapped emissions back in the air (in my opinion)
It's supposed to eliminate the pollution.
Have you ever followed one during regen -Lame
ttman4
Last Nite's Dream..
OK @Clb maybe I've sorta heard a little about some this stuff. I've never known that I was ever following one during Regen. (Probably followed something that was belching smoke & spitting green chunks at me, but I didn't know what was happening)
Years ago our neighbor was talking about his son working for the Forest Service here in Or. He drove a Forest Service pick-up, maybe a Chevy, or something, I don't remember.
Anyway he was talking about working out there in forest, dry & flammable, driving around, and something about every now & then the truck would belch fire out tailpipe. Something to do with cleaning itself up or something, something to do with all this wonderful new
anti-smogg stuff that we're supposed to be happy with.
On subject of "Beating the MPG horse" .......Personally I think we should be & could be getting 40-50-60 MPG on/in our diesel & gas rigs. Buuutttt.............Every time I tell the "Big Boys" smart stuff they never listen to me!!!!
  • Like
Reactions: Clb
Clb
Another old truck
nannyfornia
So @Indadesert
Care to respond?
Not cool calling out stuff then not backing it up....
I'm going to fully disregard that stuff.
Thanx amigo
FrozenMerc
SW Missouri
One more Data Point for you Clb:
Ran up to Chicago and back before Christmas with my 24' Pace car hauler. Just over a 1000 miles round trip. Going Up was with an empty trailer and during a snow storm, so average speed was low. Return trip had a lightweight '62 Ford Galaxie in the box, clear roads, and ran mostly 75 mph. Weight doesn't matter much with that trailer as it is little more than a big white parachute.
'85 F350, DRW, CC, LB.
3.73:1 rear gear and ZF5 transmission.
7.3, CDD 90 cc pump and Stage 1 turbo setup.
Oregon Cam Grinders cam.
6.9 heads and manifolds.
3.5" Banks Exhaust
Speedo is 5% slow, and I account for this in my calculations.
Trip up averaged a bit over 11 mpg, but again did alot of running in the 45 to 55 mph range due to the weather. Ambient Temp ranged from 35 deg. F in Springfield to -5 F in Chicago.
Trip back averaged right at 8.3 mpg. Lots of 70 to 75 mph running. Ambient temp ranged from 25 deg. to 45 deg. F.
I typically get 14 to 15 mpg running empty, mostly in town/city driving, a bit less on the freeway running empty.
As an interesting comparison. The following week we took off to Minnesota with the same rig, but a '60 T-bird in the box. The '85 started bleeding engine oil near KC, got left at a Ford dealer, and I had to rent a truck. Rental was a 2026 F250 with the 6.7 and the 10 speed auto. CC, LB, 4x4. Towing the same trailer, that truck averaged 13.5 mpg over about 2200 miles, with a noticeable tail wind both directions. Lots of 70 to 75 mph Interstate running. Ambient temps ranged from 45 deg. F to 10 deg F in NW Minny. I was surprised with the 10 speed, very little gear hunting and it kept the engine between 1600 and 1800 (peak torque) consistently. I will give the Ford engineers a thumbs up for the tune on that one.
my apologies for not being able to help out here bud.
i can tell you that im getting 45 MPG out of my IDI, but that would be too democratic for me.
i wouldnt beable to show you hard numbers. nor could i have any pride.
but i can say with the upmost certainty, that if you dont drive your truck, you cant get any MPG
might just be the cold ones talking. :joker:
Clb
Another old truck
nannyfornia
:cheers: Considering how much I drive it, we could use the earth's rotation to calculate the miles travelled by the thing with the key off, and probably be very impressed with the numbers...
The rockcrawler averages 16 round town, when it wants to.
The treehugger california model civic does 25 in town.
I've not put 30k on this since I joined, and drove it to Ak n back 1 spring.
So I'll keep sniveling about not having to pay off a 85k towpig for a while longer.
Smitty 90idi
Army
California
1990 f350 cclb 4x4. 33s E4od 3.55 gears 7.3idi banks waste gate. I almost never run empty but when I do I get around 23-25mpg on flat ground at 60mph in 4th/OD Usually towing the 10.5k horse trailer around 12min at 55 in 3rd. Remember speed kills. The speed limit back in the 80s-90s was 55 and too going it was 45. So slow down. Wind resistance is a very real thing.
Finally some one else that drives like I do. I’ve got 33s but 4.56 gears. Empty 20-22 at 55 and young in the 10-12 range. Never tow or haul I’d OD. It’s terrible for the trans. Yes even a manual.
jwalterus
Made in America
Air Force
Garrison, ND
Well, since this thread has been resurrected.....
My IDI has been off the road for a few years, but the notebook I used for logging mileage is still in there, I just checked it.
Over the years driving in town (25-40mph), I was getting 14.7MPG consistently on #2.
Highway I would get 18.8MPG unloaded (except the wife and 2 kids at the time) if I kept it under 60, I'd get 15.7 driving at 70mph on #2. Had a couple anomalous trips that show 22.1mpg under 60, those were coming back from Gillette, both times note road construction, so I'm thinking there was a lot of downhill at 40mph or less.
5400lb bumper pull trailer (hauling black dirt as a contractor) I would get 12.3 in town.
Moving to where I am, I was getting 14.4 MPG averaged on the highway at 55 with the truck loaded and a loaded truck bed trailer behind it, made 5 trips (52 miles one way) like that, so it was 52 miles loaded x5, 52 unloaded x4.
I have an old greyscale Garmin GPS unit I use for a speedometer and trip logger since my speedometer was never reliable, and I only burn #2 religiously dosed with PS.
Clb
Another old truck
nannyfornia
I guess I should realize that my driving style will not get me mpg's, that said' I have had to dd it for awhile while I swap axles on the rockcrawler and I am seeing low double digits, still not touching the 15 mpg number I expect to get...
But now that I'm not towing with it much anymore...
Might need to swap it for one of those carlike f150 cush mobiles for just an occasional load of gravel, and moving the kayak around...
ttman4
Last Nite's Dream..
Well, like I said before, my 90 model crew Dooley used to get 18 to 22 out on the highway, cross country, pulling a trailer, etc., etc. Keep rolling across the country, fall off the hill 70-75, keep steady pull going up the next Hill, etc
When I got down to about 14 or so at about 120,000-130,000 on the pump and injectors I had them rebuilt and checked out. Mileage went back up to 18 to 22.
Now when I drive it, I do good to get 14 with today’s Fuel.
Disgusting!
  • Like
Reactions: Clb
Clb
Another old truck
nannyfornia
Well considering that he hasn't stopped by to support his fantastical mpg claims, I am reticant to comment on this...
I'm sure that one can eak out superior mpgs, but doing the math on gps and gearing isn't something that gets alot of mention here...
Carry-on
Ps thanks to carb for killing half the mpg's with ulsd!
bneumann22
