Eta
61k factory miles.
aftermarket ats 093
3" downpipe
Holly red no regulator
Zf 5 sp. 4x4 , 4.10:1 lsd single rear tire
Stock spec tires
Pullind a dry 6k 5th wheel loaded sparcley on mostly lo land rolling hills ans flat Valleys.
stock EVERYHING ELSE.
So every mpg thread here gets derailed into a performance category .....
That said
Details of my whine
are as follows
I got this junk with documented @ 30 something k miles in so cal, best mpg babying it up the 101 was 14 ish empty that day, fast forward 25k miles later, and the towing mpg just kept dropping from a best of 10-12 tojust before I put in a new pump of like 7...
I swapped to brand new delphi bb codes from Russ @ maybe 40 k.
at 60k I put in a r&d 80-90
timing At 7 At 13# boost,runnin empty @ 75 highway got 12.4 mpg oh joy...
then bumped the boost to his recco of 15# @7 deg, no change.
I tow the exact same route with the 6500# 5er every time for this discussion...
It is around a 120 mile round trip I usually burn 1 tank.
Best mpg has been 8.41 worst around 7
I have tried 7 degrees and got 8.41 then I tried 8.9 and got 8.11.
Driving style is nursing it for mpg.
I did 1 run playing with all of justins glory of calibration and fuel delivery and lets just say I aint posting that mpg as ford would puke...
So what am I doing wrong besides beleiving the net warriors fantastic mpg claims?
what do you tow and how many #'s?
61k factory miles.
aftermarket ats 093
3" downpipe
Stock spec tires
That said
Details of my whine
are as followsI got this junk with documented @ 30 something k miles in so cal, best mpg babying it up the 101 was 14 ish empty that day, fast forward 25k miles later, and the towing mpg just kept dropping from a best of 10-12 tojust before I put in a new pump of like 7...
