Oil filter and wrenches??
Noiseydiesel
Hillsboro, Ore
Yeah, this potentially beat to death subject is back again, Coming due for another oil change and cussin' the thought of changing the filter with a rotten strap wrench that doesn't have enough length to spin the filter off. I used a pipe extension on one and bent it quite nicely. Now it is pre-bent for my convenience. No, I did not dry gasket the filter upon installation last time or the one before that either .
Next is the filter type of question. Wix and Motorcraft because of the built in check valve that others are missing such as Hastings and with the built in valve that prevents dry starts in the morning.
I thank you for your time,
1mouse3
il
What about a #3 or any other sharp rod, then hammer it around?
Noiseydiesel
Hillsboro, Ore
Without making a mess would be nice. I do have an 18" chisel that was attracting my attention.
I think the chisel might be an option next time, but . . .
Filter needs to get ordered soon enough. Local parts stores are impressively priced.
Noiseydiesel
Hillsboro, Ore
Yeah, I might be stuck playing the "poke the bear" game.
Oh well. I will look into the 51734 filters onto a '94 7.3 idiT
Looking at your cross member is my next large project. I couldn't find a '94 7.3idiT crewcab dually 4x4 so I am in the slow process of building one. Placement of the . . . I just lost a word, Trackbar bracket to the cross member might be fun. I am hoping the 2WD OEM cross bar has dimples in it to drill for mounting the bracket. If not, I can swag it.
Randy Bush
Great Falls, Mt
I have started punching a hole in the bottom of the filter so it does not run down my arm when removing. Also have a large pair of channel locks that works pretty good for removing the filter. Ford never built a OBS in a crew 4x4 dually. Just in a cab and chassis standard cab. All the dually 4x4s where custom built.
TahoeTom
S. Lake Tahoe, CA
My local Walmart has the Motorcraft powerstroke fl1995 filters for around $12. The filter is larger and holds more oil but will fit an IDI. I am able to remove filters with a strap wrench. I do it with the oil hot, so it may turn easier than cold.
chris142
SoCal
When you install the new one oil the gasket. Put it on then back it off just enough to relax the gasket.
CDX825
filtration nut
Litchfield,Ohio
None of the filters for this application have an anti drain back valve. Neither the powerstroke or the IDI filters have them.
This is the EXACT method that I use too. I do loosen the filter just enough to break the seal before I poke the hole in the filter. It keeps the oil off of the channel locks that way. If you use a small hole, it's pretty easy to cover it with your finger to keep the oil inside the filter while you spin it off.
My local Walmart has the Motorcraft powerstroke fl1995 filters for around $12.The last time that I bought one at Wal-Mart, it was still $9.99. $12 still isn't a bad price these days.
None of the filters for this application have an anti drain back valve. Neither the powerstroke or the IDI filters have them. I was pretty sure on this too. They don't need one since they hang down instead of horizontally.
Tom, when you come down off the hill to Costco, Walmart is right next door as well as In N Out.
I usually don`t have a problem getting the filter to unscrew. I also use one of this type wrench.
I also use one of these pans.
Loosen the filter a turn or two, let it dribble for a few minutes. then unscrew and drop into pan.
Wipe off the base and make sure old seal came off with the filter. Lift your new filled filter that has the oiled seal and screw on. then give it another 1/3 of a turn.
With a second pan I drop the engine oil and let it drip a couple hours. Wipe off pan and screw in drain lug. Finally fill with your favorite flavor.
Noiseydiesel
Hillsboro, Ore
Green pan is anti-freeze. Black pan is oil.
I went looking at Rockauto and found the only filter listed with the anti-drain back valve is the Motorcraft . . . FL784(A?)
I am picking one of those up tomorrow morning and will give it a try.
gnathv
Athens, Al
Why are you worried about the anti drainback valve. As you’ve discovered it’s full of oil when you change it.
Noiseydiesel
Hillsboro, Ore
Keeping oil in the engine as much as possible is a nice thing to have. Listening to bearings rattle upon startup might not be too good. Not loud, but it is present. Given enough money and time, an accumulator to pre-charge the oil system and build pressure prior to start-up, lined block cylinders, nitrated crank and cam. Theoretically would never wear out. Well, aluminum pistons would still wear with age.
I believe that the FL784 was the filter that was called for on a 7.3 IDI. I thought you were wanting a PSD filter. I'm using the FL1995 filters on my truck (soon to be trucks). Personally, I don't care one lick about the extra quart of oil capacity. I just want the better filtration that the PSD filters have.
720Diesel
