Oil Catch Can Drain Point
Kevo1288
Worcester MA
Do you think a 3/4 inch bung would work or does it have to be closer to 1 inch or 1 inch coming out of the driver side valve cover?
Kevo1288
Worcester MA
@Thewespaul do you think dual 1/2 inch ports one per valve cover with 2 catch cans will be enough? I know the factory single port is 1" , however the biggest port I can find on a catch can is 1/2"
Thewespaul
Bulverde, Texas
Is that 1/2” thread or tubing inside diameter? My setup will be using two -12 an bungs, which is 3/4” tubing OD and a 1 1/16” thread.
Kevo1288
Worcester MA
Well I found that mishimoto makes a high flow catch can for certain applications that has 2 1" ports (1 in 1 out obviously), which is perfect. Meaning I only need to run one can. The whole AN chart and size confuses the hell out of me. For this a -16 weld in bung should be good for 1" id hose so that's what I will roll with.
