I have had this tick noise for a while (here we go again ) and it just drives Me crazy . Many have heard it and say it is a miss, I just don't totally agree with that wich is why I will give it a shot by removing the zf-5 out of there. You see I have the feeling this noise is coming from the flywheel and I believe so since there is been a small leak that have developed to the point where is almost drip oil, this leak is from the dipstick o-ring and the main rear seal, so my buddies I need to know a few thing if you can answer Me.
- Is there a o-ring I can get for that dipstick?
- What do I need to know in order to remove this tranny?
I have done the following:
- removed UP nd Down pipes (wich I just repainted with High temp paint)
- removed starter
I have the feeling I need to remove the cross member if I want the tranny to go down (I do have a tranny jack). Do I need to raise the truck or I just leave it at the high it already is (in order to remove the tranny)?
There is other stuff I don't know for sure if it has to come out like the master cylinder for the clutch, also is there anything else I have to look for any tips?
I will be replacing the rear seal, so where can I get the tool to remove/replace or I can do it with something else?
Well that is pretty much it for now, I'm sure questions will arise while I go forward on this project, I do hope I can do it in a week so I can have the truck runing for the weekend.
Thank you for any good tip, Exekiel.
ps- I removed and reinstalled a transmission before but this one is much larger so dummies tips are appreciated .
- removed starter
