New info on possible turbo for my truck
mblaney
Ottawa/Ont/Canada
I have a line on a "mint" turbo that is supposed to fit. I don't know much about these, other than seeing if the wheel has a lot of play; any insight or suggestions for me when I go see it? Seller says I need to get my own oil lines (supply and return) which I am not worried about... and need to fab a "exhaust pipe to turbo" which I assume is the downpipe?
All I have are these low res pics. Any info on what this appears to be and value would be appreciated.
riphip
Memphis, TN.
You have the downpipe, check for rust-out holes. Will need a pipe from downpipe to present exhaust system if you stay with that.
New free-flow would be much better
Rick
May just be me, but for what's there and the shape it looks to be in, I wouldn't give more than a couple hundred. @typ4 for rebuild.
laserjock
Almost there...
That's the non-gated banks based on the square box. Parts are tricky. I think I read recently that auto vs manual matters on the up pipe on those.
typ4
Newberg,OR
Turbo parts are easy, mounting parts are not. Full rebuild cost, depends on what you want. Pm me.
