Moose IP
65sixbanger
New Braunfels, Texas
Although my truck is not going to be a powerhouse, I have been thinking about upgrading my fuel pump to that "Moose Pump", but what are the performance gains? And is it worth it?
The Warden
MiB Impersonator
Fog Bless Pacifica (CA)
As I recall, you pretty much NEED to have a turbo for a Moose Pump to be worthwhile....your sig says your truck's n/a. I don't know if Mel can make a Moose Pump tuned for an n/a engine; hopefully someone who knows better will respond shortly. Certainly, I would be greatly concerned about exhaust temp...
Diesel JD
Gainesville, FL
You're stock pump will make more than enough fuel to melt that N/A stock engine together. You could get a Moose Pump and turn it down and or watch the EGT gauge like a hawk, but frankly I don't see the point.
The turbo it and... Add an intercooler.. That way you will use every bit of the moose pump...
