Dsl_Dog_Treat
Well, since I was in process of a really crappy week, I decided to take a gamble and do a little more research on Mater before I pulled the motor.
I figured that I'd start with #3 since it showed the lowest compression numbers.
Glad I did because as I was trying to remove the IP line, the entire injector was spinning around. Dang thing was loose in the hole and never showed any symptoms of such.
I got it out, threw it on the tester and found it ******* like a cow on a flat rock. As you can see in the video, the pintle is stuck wide open.
Cause of death????? You can see in the picture of the 2 injector tips that the one on the right has seen some extreme heat......Caused by the injector being loose and seized the pintle.
Pulled a few more injectors out, tested them all popping off at 1950 psi.
Grabbed one of my cores, gutted it, re shimmed it to match and TADA!!!!!
No more hammering noise and running much smoother.
Took him for a spin around the block and am happily satisfied that I resolved the problem fearing the worst.
As said in the movie Evan Almighty.........Do the dance!
Who would have guessed?
