Lykkan's rebuild thread
Waystro
No Class
South Texas
I stopped watching tv when they started making me pay. -cuss
I just watched Fox and pbs cause those where the only free channels not any more Tho
Lykkan
Sarasota Fl
You're not missing much lol. I only have broadcast channels as well and download stuff that I want to watch.
I'll post an update later tonight on the truck situation.
Lykkan
Sarasota Fl
Only spot of real rust on roof
Pics under the chassis. Living in Michigan all my life, this is hands down the cleanest vehicle I've ever owned.
Lykkan
Sarasota Fl
Mounted electric fuel pump on the fuel rail.
Cut the original metal line and flared both ends
Pre filter
Cutting the lift-pump to seperator lines and hooking the rubber line to it.
I think I'm closer to bleeding the lines, but the batteries are so ****** and can't mess with getting new batteries for it til after closing on house this weekend..
FastestIdIinthe707
Santa Rosa California usa
looks good. i put an electric lift pump on mine too after it went out on me during the truck pulls....:mad: but i also frame mounted my fuel filter and kept the fuel line on the driver side of the motor right into the back of the IP.
FastestIdIinthe707
just so i didnt have to cross over under the motor. also with my filter on my frame i have alot more room up top so i could make a custom intake. im gonna clean up the hoses going over and under my intake just haven't had time.
Lykkan
Sarasota Fl
Hi everyone. It's been forever, but owning a house has finally calmed down. Picked up a 98 mustang GT in the meantime and sort of modded that out quite a bit...
Anyways, finally got the diesel started. As mentioned previously, replaced all of the injection system and upgraded to electric fuel pump.
I have the timing advanced slighty from the visible mark on the gear cover. I haven't warmed the engine up yet but when cold it has a clack to it (like a power stroke) and when I get on it, it blows black smoke and sounds like it's backfiring?
Going to retard the timing a bit and see how it sounds. I know it's not really possible to time it well when it's cold, but she starts instantly everytime.
Here's a video of it running:
https://youtu.be/3GvEcNL5JiY
Any tips on where I should set the timing? I don't have any timing equipment. Thanks
sassyrel
iowa
someone, that has one on here, may be close to you..timing by ear,,wont get it...
There are meters available on ebay.
There are ada0ters new that can work with timing ligjts az well.
Lykkan
Sarasota Fl
More information please... what you said is quite vague. Do you have part numbers, a link to a page with more info? I've only found outdated information on this.
rhill5353
