idi turbo
Chubbs090
Diesel-holic
Martinsburg,WV
dose anyone have the specs for a hypermax, ats, or sidewinder turbo? i want to put a turbo on my 7.3 without spendin to much so i figured id make my own kit
FordGuy100
Silverton, OR
I have a ATS wastegated unit, and I believe the turbo itself is a TEO4H, or something like that. There is a guy on here, his name is Russ (aka Typ4), and he should chime in cause he knows turbo's like nobody else I know.
Hyde
N GO SEEK
Idaho
Upgraded turbo for a DSM should be about right off the top of my head without comparing maps and such.
Chubbs090
Diesel-holic
Martinsburg,WV
ive been all over the net lookin for what he meausurements mean so i can find a turbo for my truck and im on a $500 budget
Chubbs090
Diesel-holic
Martinsburg,WV
i dont wanna pay $1500+ for a turbo kit when u make ur own has is that garrett workin out for you? and other suggestions on a good turbo
RKOCH
Fellow Oil Burner
Yorktown, Virginia
It works awsome and is perfectly sized for the engine. But you won't get one under the hood without a body lift.
Diesel JD
Gainesville, FL
Also the Banks Sidewinder used the same turbo as the Mitsubishi Eclipse, might not be a bad one. You may also could use a turbo from the GM 6.5, not sure.
Seven4eight
