dose anyone have the specs for a hypermax, ats, or sidewinder turbo? i want to put a turbo on my 7.3 without spendin to much so i figured id make my own kit
I have a ATS wastegated unit, and I believe the turbo itself is a TEO4H, or something like that. There is a guy on here, his name is Russ (aka Typ4), and he should chime in cause he knows turbo's like nobody else I know.
Also the Banks Sidewinder used the same turbo as the Mitsubishi Eclipse, might not be a bad one. You may also could use a turbo from the GM 6.5, not sure.
