Hey David I'm going to PM you my phone number in case you want to talk further. Honestly I am not sure what the failure point on my tester was even now. I had no visible leaks, and without an injector installed I could easily pump fuel through the system. It seems like the problem was once I got to 100 psi or so somewhere there was a leak. I never did find it and got frustrated/gave up. This can be done, I assume you have seen the videos of homemade testers on youtube that work pretty well. I can offer you some reassurance about your rebuilt injectors, that is that you can pretty much ignore what is stamped on there. All the codes are more or less obsolete, and pretty much all the new and rebuilt injectors out there are being built as BB for most IDI applications or the G codes for the factory turbo pumps. If you like what you see when you pop test your injectors throw them in there and don't worry about it, if not make Pensacola Diesel make it right by you.
